Handy hank
- Round Hill, VA
In acting as my daughter's agent following a home inspector check out a prospective home purchase, he measured 4.6 Amps on the main water line at the point where it entered the home. He wrote this up as needing an electrician to inspect. The electrician pooh-poohed the reading but did check things out and found a ground clamp on the gas line to be not to code.
I have been unable to find any reference to what a nominally acceptable level of current might be. The home inspector writes everything up if it exceeds 300 ma. This seems a bit low threshold. Are there any rules of thumb readings?
