Ohms law
- Sioux Falls,SD
I did not think you could use a individual wire for grounding purposes unless it followed the outside of a conduit. I recently was working on a remodel and I ran into a NM cable with out ground, someone ran a green insulated #14 awg solid ground wire to a water line so they could have a grounded receptacle. I was curious where does it say in the code book that I can do this?
My boss said it was ok, but I am kind of questioning this method. Any input would be great! If its correct
