- NE Nebraska
- EC
I'm sorry but that makes no sense at all to me. If your conductors are low impedance, and the load is not a really high impedance capacitive coupling is negligible. It only comes to play with high impedance loads, like in the high K ohm or meg ohm ranges.We connect single phase loads between line and neutral (connected to X0), which are at a considerable distance from a HRG transformer. So even though the phase to neutral voltages at the transformer terminals are the same, they are not the same at the single phase load terminals which are at considerable distance from the supply transformer due to unbalanced ground capacitive coupling as mentioned in my earlier post.
Unless you are talking about medium voltage HRG, and I am not going to go there, because I don't know a lot about it, I totally disagree. I am talking about under 600 volts systems.
