- Placerville, CA, USA
- Retired PV System Designer
+1I think the reasoning behind not using an SEU in a sub in that the neutral is bare. Landing it on the neutral bar could cause it to also short against the can bypassing the separation in a subpanel.
I think you've found the explanation behind the wording that justifies the interpretation that an insulated neutral is OK in a subpanel.
You can have the same problem with accidental contact between neutral and ground wherever the SEU comes in through a bushing, etc.
