- Windsor, CO NEC: 2023
- Hospital Master Electrician
Yes. Thank you for finding the exact scenario where you have to use the values in the book to get the correct answer on a test. :lol:
The code rule is based on circular mils provided in Table 8, Chapter 9.
Submit a proposal to amend the table if you find it to be unacceptable, but I will continue to use the book values in the field and in class.
