- Tennessee NEC:2017
- Semi-Retired Electrician
If you're installing a stand-by generator and a load calculation is required, how do you do that?
If it's mostly general use receptacles and lights, do you use the sq ft, or if you know what loads are going to be used on the circuits, do you use that?
Or is it a combination of the two?
This is just a 17Kw generator with an ATS that also has a built in load center. It is prewired with a whip to go into the panel to pick up the desired circuits. I think it is for 14 circuits.
