 - Tennessee NEC:2017
 - Semi-Retired Electrician
I had a service call today for flickering/dim lights and some receptacles not working. It was in a barn about 200' from the house main.
First I thought he had a loose or open neutral, but the voltage measurements didn't show that. I only showed around 190V to the sub panel at the barn but there wasn't any high voltage on one of the legs.
I had around 72V on one leg-neutral and around 119V -neutral on the other.
So I decided to meg the conductors. This is where I'm confused.
Readings from: Line A to neutral - 11G
Line A to ground - 11G
Same with Line B to neutral/ground
From line to line the reading was 0.0 M
I did determine from the voltage readings that the A leg conductor was bad. Probably underground somewhere since this was an underground feed. I just can't figure out why the reading was the same on both legs to neutral/ground.
I would have thought the bad conductor would have had a different reading.
I'm guessing the low reading on line to line is due to insulation damage along with damage to the wire its self. But why wouldn't it show on line to neutral/ground testing?
