emtfire148186
 - Downingtown, Pa
Ran into a issue today with a service.  A guy is redoing an old store front  into 3 small apartments.  My plan is to come down the side of the building about 25' into a 3 gang meter socket. Come out of that and go along the building on the outside to the 3 units. Its about a 40' run from the meters. This will all be in ridged conduit. The city codes inspector said i needed a disconnect at the meter since my run was more then 5' out of the meters. I could be wrong but i thought that was the rule if i was running inside the building. I cant fine the section in the book.  Anyone know the section off hand? Thanks a lot
