Power for cameras on light poles
power supplies are available that can be run directly on voltages as high as 480V, so the supply voltage of the lights should not be an issue.
I don't see either a solar or battery powered solution being practical long term for this application. Maybe they just have to live with the idea of no surveillance during the day.
There might be some options depending on how the things were actually wired and run if you are clever.
You might also consider installing a camera with an optical telephoto lens at a remote location where it is easier to get power. There are some very remarkable cameras available that do this.
If the luminaires have twist-lock receptacles on them, you can make the circuit hot 24/7 and put a control at each luminaire after the camera power supply. Or even if you don't have receptacles already maybe it would be easier to install a control at each light instead of installing a charger & battery at each light...
Update.
As some of you pointed out, the power supplies are not quite lasting all day.
No decision as yet as to whether this is going to be okay with the powers that be.
Thanks for all the advice.
Nice. Took care of your problem.
My big idea was to leave the poles powered 24/7 and put a photo cell on each pole to control the lights.
