I am using these ABB enclosed disconnects:
https://www.platt.com/CutSheets/ABB/RotaryDisconnects-Fusible-Enclosed.pdf
These come with fuse cover holders, but no terminal shrouds to cover the line terminals. ABB sells these terminal shrouds (please see attached).
Abb informed me that they do not fit these with shrouds, but that "The issue here is not just if the spacing exists for the shrouds to fit but the bend radius for your cables and or how you will attach cables into the enclosure.
This should be according to your local electrical code and should be reviewed as well prior to making a decision on the use of the shrouds."
I need help figuring out what parts of the code apply to this situation
