jimmy_mcquade
Hi all,
most of the light fixtures in the house is rated 60 watts.
I understand that light bulbs are rated in wattage, and they give off heat.
I also know that watts is a power rating.
does the wattage of a light bulb mean that this is the amount of heat they are giving off?
the reason I ask is that with the new energy efficient bulbs you get more light for less wattage.
for example, a 100 watt bulb uses only 53 watts of power.
following that logic, does that mean I can use a 100 watt energy efficient bulb that uses only 53 watts of power in a light socket meant for 60 watts?
am I on the right track or a I missing something?
thanks,
jimmy
thanks,
jimmy
