I have a situation where I have an existing 110vac piece of equipment that has to be changed to a new one. All that is available is 24vdc
I have several existing wires in a conduit with other 110 vac circuits, and a class 2 24vdc power supply in a panel with a PLC
It is my understanding if the power supply is class 1, I can run wires from it, in the same conduit as power circuits if the conductor insulation is high enough for the highest voltage
Can someone suggest a replacement for the Class 2 power supply to a class 1 so that I can use the existing wiring... the only thing the dc power supply is running right now is the PLC controller itself.
thank you
thank you
