Short answer is, no.
There really isn't a longer answer.
I agree.
I think you are forgetting how many engineers we have here.
OK. Let me start by giving you the derivation of the word, "temperature." It comes from the Latin word, "temperatura," which means "a tempering." When applied to the conditions inside a conduit . . . .I think you are forgetting how many engineers we have here.
If conductors are derated due to more than 3 CCC's in the same conduit, can the conduit be upsized to counteract the derating? Conductors are derated because of heat so you would think a larger conduit would dissipate this. Thanks.
I think Gus once pointed out a bigger oven with a small element my take longer to come to heat but eventually it will.Can some one tell me how having larger conduit means the wires will be cooler? Once you get to the point that all the wires are resting on the conduit that is?
Roger
But given time it may.But a larger poorly insulated oven may not get as hot.
Tapatalk!
The heat generated still has to get out of the conduit via its surface.Hypothetically speaking,
If you have 15 conductors and you could somehow float the conductors in the raceway, so they are not resting on top of each other, do you still have to derate?
For straight runs only I guess. Or do they make fittings for bends?Just run some finned EMT.
