enigma-2
- northern Indiana
210.52(C)(1) is reads "Wall Countertop Spaces. A receptacle outlet shall be
installed at each wall countertop space that is 300 mm (12 in.) or wider."
I have interpreted this as to only apply to countertop spaces in which there was a wall (space) located behind the counter.
Problem : Assume a kitchen countertop with walls behind except for a space approx. 8' wide where the countertop extends through the wall into the dinning room. At this point, there is no wall space to mount a receptacle. (The walls stop at the opening where the countertop extends into the next room.)
My argument is that 210.52(C)(1) does NOT apply to this area as there is "wall" countertop space. (It only applies to the countertop where there is wall behind.)
The inspector reads this to still require receptacles spaced 2' and 4' on-center (even through there is no wall.)
There is no definition as to what a "wall countertop space" is. therefore open to interpretation.
How do the rest of you feel about this?
