electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
I have been doing lots of reading on the subject and I am just not clear on several things:
1. Isnt it true that we cant generalize that an electronic ballast is a non-linear load? With modern power electronics and designs, is it fair to say that a modern electronic ballast could be a linear load?
2. Does the term "total harmonic distortion" essentially quantify how non linear a load is? If so, about what would be the value that would differentiate between a linear and non linear load in the terms of the NEC?
3. Can the neutral current in a 3 phase MWBC be calculated from the THD value? Is it as simple as THD X current X 3 (assuming 3 identical loads, one on each phase)?
I appreciate any clarifications on the topic.
