PVC conduit to PCV nail-on boxes in new construction
How would you minimize materials cost on a project like this? Romex everywhere possible (interior walls and attic) then switch to conduit (or smurf tube) (or MC) in exterior concrete filled walls?
Yes, absolutely. Along those lines- don't be shy about using J boxes where and when it serves your needs. I only mention this because there is a bias against using them "frivolously" among a lot of resi guys.
Commercial guys have their issues too, like all the set screws have to point the same direction and other such nonsense.
i like them all pointed down so I can do a walk through and see who left one loose. You would be suprised that how often I see those set screws not even attempted to be tightend.
If they are pointed up then you might not be able to see them to check. A bit sideways is best.
How do you point them down on a vertical run, or do you use some kind of special "right angle" set screws?:cool:
You just put saddle bends in the conduit everywhere you need a connector in a vertical run. I thought everyone knew that. :)
PS: Allows for expansion at the same time.
Tapatalk!
Ok point them away and visible while looking at the front of the box or run and without getting a ladder out and looking down. :rant:
