Hello.
There's and underground rigid conduit that comes into someones basement at the panel location (below grade).
Along the line, someone installed an FS box on the other end in the yard which has rotted (disintegrated) and there is water going into the conduit and into the basement.
I will continue the pipe run to where it needs to go with pvc, but sometimes those couplings leak, or it may also be possable that since this pipe is older, it may also have some rot and be leaking somewhere else along the pipe run.
I'm thinking about 90ing when it comes in the building with rigid to get it up above grade level, or dig outside and do the same thing to get it above grade level.
Or, Fill the heck out of the pipe where it comes into the building with silicone.
It may not be too smart.
But I know they want or suggest putting duct seal in conduit to prevent condensation, is there any article that mentions that I can't put a tube of silicone in it?
I may reevaluate the job and run a new piping system but, it won't be easy.
Just wondering about filling it (which I'd rather not, but).
Thank you
Thank you
