- Massachusetts
Yes, I meant 42"...thus ends my experience with Tapatalk...
I can't throw stones, my spelling is poor at best and spell check often makes it worse.
I resemble that remark..
Metal frame but soft sides.
It could be 75' in diameter but if it holds less than 42" of water it can be a storable pool.
I have a 15' diameter one.
ahh...see told you it was confusing. Regardless the diameter is pointless. The depth of the storage pool shown in the origional OP post has a depth less than 48" so defer to 680 Part I and III.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
680 says pool holding 42" of water or less, correct?
Manufacturer spec says 52" wall with 90% max fill capacity. This would be around 46" of water?
How is a 24' diameter steel pool "storable"?
That is a permanent pool.
I was asked to install an outlet for one of those simple snap together above ground pools. I told the owner I couldn't just put in a outlet until I knew if said pool fell under the usual nec bonding rules.
Here is the exact model In question
So my question is the #8 wire around the pool with 4 points of contact ending at the motor along with the water bond would be required for such a pool?
The hose connections for the pump look proprietary so It doesn't look like I can easily do the 1" thread in water bond using a standard cpvc tee. The skimmer is definitely not big enough for the plate style bond either.
Where do metal removable ladder fall under this?
The pump is all plastic and has no ground lug and comes with a 25' factory whip with a gfi plug.
Would a GFI circuit still be required? and is the 25' lead even legal in a permanent installation?
In my own town any pool that is over a certain height (I think it said 2') and surface area that doesn't get emptied every night is required to be installed under the normal nec pool standards. Towns are requiring permanent fencing around the blow up ring style pools and any non rigid side pool 48" of less.
I'll call the inspector I know from the towns approved list and see what is required but wanted to see what is going on in the rest of the country
That's the original post. He says that "...In my own town any pool that is over (2')... and that doesn't get emptied every night is required to be isntalled under the normal nec pool standards..." It seems everyone wants to ignore that and beat each other up.
The questions are about bonding the pool, pump & ladder and if the receptacle which the GFCI plug will plug into should be GFCI and if that 25' cord is legal.
One question which arises is whether that pump is required to be listed. Anyone know if the pump is required to be listed? Seems risky to not bond a pool pump these days.
I think the key point in my statement that I missed is the fact (in this particular case) no metal parts are involved.
I know that pools are risky which is why I want to educate myself. Although this tennis match looks futile it has caused me to dig deeper into the codes which I am unfamiliar with and I appreciate that.
Again, thanks to all...I am hear to learn :thumbsup:
And even if that is all that is needed it still has a good chance to be more then $100.I've had people call me about installing the electric to these above ground pools. They said the pool place said it shouldn't cost more than $100 for the electrical, which they usually tell them "you just need a place to plug it in"!:rant:
