What is your procedure for personnel safety ground while working on a transformer after you test to make sure transformer is denergized ?  480 v to 208 v trans.  Does connecting the proper size ground wire connected to the grounding system and a across the 3 phases suffice.  I know you connect to the ground first then to the phases and disconnect in the opposite order.  any other suggestions?
