(You can read any response I have given in this forum and see that PV is one of my weak areas
, hence my question)
I recently looked at a PV install where the inverter had a nametag noting the output was "240". In the accompanying instructions it shows a neutral and "ground" connection. The points identified were obviously common to each other (verified by a meter). Inspector's dilemma: This is an interactive system. If a neutral and equipment ground are both brought from the premises wiring to the inverter we have a violation of 250.24(A)(5) by connecting them together.
How is this addressed in installations ?
