- New Jersey
- Journeyman Electrician (retired)
Definitions aside, is there a real inherent danger if this is not considered a structure and wired accordingly? This entire concept of a separate structure seems rather silly when you apply it to an installation like this. For example, if the same pole mentioned in the OP were somehow attached to a building then all of these separate structure rules would not apply. Does moving the pole some distance away make this entire installation less safe?
