Opensolar
- United States
I spent some time to figure out that PV AC disconnect is considered to be a service disconnect and has to have bonding at the switch and a GEC from AC switch into main panel board grounding electrode. (The existing main panel board already have G-N bonding there)
Question:
The rationale for not having a neutral to ground bonding at the AC disconnect for load-side taps is to avoid parallel current paths. How does supply-side tap avoid this considering we are tapping into the same neutral bus? ( regardless it's on supply or load side.)
Any thoughts?
Thanks
Question:
Any thoughts?
Thanks
