AdrianWint
 - Midlands, UK
Guys,
I'm trying to put together a shopping list to build a US power network here in our UK factory.
(I've got the 60Hz supply sorted - I'm using a 30kVA static frequency converter driving into a 400 - 208/120V custom transformer).
Where I'm struggling is putting together part numbers for the Receptacles/boxes/lids.
I've discovered that I can buy from Grainger & they'll ship to the UK with no problems, but, obviously I need to understand what I'm ordering & how these combine together - that comes with experience that I don't have!
All of the receptacles will be surface mounted & fed by conduit (ie. Not sunk into a drywall or masonry wall. I know the US uses imperial size conduit & we use metric but I've got that covered)
I think I've decided that the cover I want to use - RACO #907C. Inside I'll use a hubble 20A 125/250V combination outlet HBL5492I. (I want to get 120V & 208V on the same outlet plate)
Where I'm stuck is finding the correct box - it needs to have screws in each corner to match the #907C cover..... but all the ones I can find only have 2 in opposite corners.
Can anybody point me in the direction of a RACO part number or where I'm going wrong?
Thanks.
Adrian
Thanks.
Adrian
