Davebones
- North Of Tampa Fl
Looked for a small attic fan listed for a attic . Just can't seem to find anything for such a small attic area .
Also what's wrong with moving some extra air?
Just saying what I've seen from experience with fantech fans, including the fact that fantech recommends the discharge duct from the fan to be one size larger. I was talking about having a fan in the basement that has to push air all the way through the house up through the attic and out, but I guess that's not what the OP is talking about.This makes no sense to me. An in-line fan, or any fan for that matter, has to be better at pushing air than it does at sucking it.
Interesting. I have hooked up many of these fans but only done the ducting on two of them. None were closer to the discharge end; most were in crawlspaces FWIW.Just saying what I've seen from experience with fantech fans, including the fact that fantech recommends the discharge duct from the fan to be one size larger. I was talking about having a fan in the basement that has to push air all the way through the house up through the attic and out, but I guess that's not what the OP is talking about.
Not even if you apply some string theory?The fan can't push more air than it sucks. It does not make air.
A lot would depend on the design of the fan and shroud and how well it coupled to the tube.Not even if you apply some string theory?
From my ordinary engineering mind it seems a fan would blow more CFM through 100' of duct than it would draw through it. Maybe not.
Personally I would not use any kind of bath fan to vent an attic. Even the fantec types.
It is highly doubtful they are designed for that type of long cycle time. Basically on 6 to 10 hours a day every hot day.
Use a true exhaust fan made for continuos duty, that also eliminates any listing issues that might arise.
Right. And I am thinking that more air can be pushed into the duct if the fan is at the start of the duct, in an open room, than if it is at the end of a 100' of duct.Not sure about string therory but fans don't suck atmospheric pressure pushes the air into the duct.
I get that. The basic question I have is does location of the fan in relation to the duct make any difference in the amount of CFM that can go in/out?This is the wrong professional forum to go too deep into air handling but from a basics view if you have a fan inline in a duct with 100 cfm going out the exhaust, then you will have 100 cfm coming in the inlet as well. Velocity could be different on one side then the other if duct size changes. Some fan designs may be better for moving air in a specific direction through the fan, but cfm is still same on both sides of the fan.
How many cfm's you get with the fan at one end or the other probably is not critical in this matter. It sounds like you need to move very little air and will end up with a bigger fan than you need.
What I like to do with fans on my own installations is install the fan as close to discharge as practical to reduce noise in the environment. My bath exhaust fans all have the fan at the outlet creating nothing more than a moving air sound at the inlet (near me). We do the same with machine exhaust fans in our factory - put the fan at the outlet so we don't have that motor at our machines. The installer had to work a little harder but that's what he's paid for!
