Bacchus
 - East Coast
The Job includes two outside spotlights with a switch and receptacle in garage:
Two outside simple spotlights
The kind with two screw in bulbs. They'll go under the eves in the back of the house. They are at the ends of either side about 70 feet between them. Both will go to a switch near the exit of the house to the backyard. The power will come from the panel.
Receptacle in the garage:
He needs it near his garage door. The builders obviously left one out by his front of his garage. I'm likely going to have to tap into one of the receptacles in the back of the garage and bring it out to the front, which will be a pain.
Misc info:
175 feet of #14 wire for outside lights & receptacles
Panel is fairly close to where switch will be
Supplies $90-120
*Some unknowns:
*Didn't go up in the attic. It was a rush explanation of job information from him (my fault there).
*Drill holes for wires in joist/rafters?
*Lay 2x4s for a track across joists?
*Attic likely clean. His garage is spotless and so is the house.
For you pros, how many hours would you bill for this? What would be your total bill? I'll tell you what I bid and why afterward.
TIA.
Misc info:
Supplies $90-120
*Some unknowns:
TIA.
