I have to add a junction box to a concrete base on an existing light pole for a lighting contactor.
There is a 1" LB leaving the pole base to 1" rigid going into concrete.
Is there a rule saying that I can not add a 3/4" knockout to the side of the LB. There will be no terminations in the LB and there is more than adequite room. I will just be routing wire from the pole through the LB and into the Jbox and than back to exit the LB.
Because of everything being rigid, if I have to cut the conduit I will have to remove several hundred feet of wire and I don't know what condition the conduit is underground.
Yes or No
Thank You
Yes or No
Thank You
