This is yet another code grey area. There is no definitive NEC answer. Most jurisdictions have some sort or trigger on building renovations that cause things to have to be updated. It could be a dollar amount, it could be a certain amount of square footage updating, etc. If this is a drop ceiling, I'd call BS on the inspector. If it is a hard ceiling you're pulling down, then I'd ask the inspection department (not a specific inspector) whether this triggers an update. If there are other other electrical upgrades being made in the room (e.g. a permit was pulled) and the ceiling is being partially exposed, they may push you to update it all.
Just how old is this wiring and how would it not be compliant if done today (e.g. is it knob-and-tube, is it ungrounded, or old 60C romex going to 75C or 90C fixtures)? If it is just old but undamaged, I think the inspector is over reaching.
The above answer is baring some state rules you have that over-ride NEC rules.
I'll ask the inspection department then, but it is a hospital with older MC cabling and not the all purpose type. so he wants all the lights rewired all because of moving a ceiling tile.
Will you get paid to do it?
Looking in the 2014 edition of the NEC, check out Annex H, 80.9 (B) and (C). Essentially, current code applies only to new work and there is no intention, absent a finding of imminent danger by the AHJ, to force an upgrade to all the premises wiring to the current code.
where in the code does it say old code compliant wiring has to be replaced? an inspector said removing ceiling tile is enough to cause for rewiring lighting.
My experience has been if a permit is pulled for a certain area/floor, etc. then they can make you bring everything else up to code, but removing part of a drop ceiling? Sheesh
