Hello!
I am trying to calculate the voltage drop for my case and I need to know the necessary factors that will change wire dc resistance ???as follows
I have 48v dc solenoid valve,6 watt,the wire length is 600m(from the solenoid to the controller) and the cable is installed inside pvc conduit and then the pvc conduit is installed in the ground at depth 60cm(soil).
