Hendrix
- New England
Can a pvc lb be installed in a wet location (underground)?
No, Im thinking that I should not allow it.Are you thinking of burying an LB?
ice
Yes in the earth. No splices. Thing is, it goes to a wet nitch light.I mainly install them in wet locations, rarely in dry locations.
Can you be more specific regarding underground. Do you mean buried by earth? or in a manhole or vault, etc?
I didn't look it up back in post 3, but that is the section with the information I mentioned there. If you bury it it needs to be in gravel or other "light aggregate" and may need to somehow identify the location as well.314.29 requires accessibility without removing earth but there is an exception that might be worth a look.
