In my opinion what you have is a finished space. The floor coverings are irrelevant. In fact, it is very hip in some areas to have painted cement floors as you describe and it does not change the fact that the space is finished.
Being that out is a finished space, no GFCI required but you can always go above the minimum standard of you wish.
I had an inspector 3 years ago require GFCI protection in a similar situation. He said that the concrete floor was the reason that GFCI protection was needed. He made the comparison to a residential garage that had drywall interior and concrete floor. It was easier to install a $12 device and feed through to the other receps than it was to argue about it.
If a basement has finished space ( walls are drywall, drop ceiling) but the floor is painted concrete, do the receptacles have to be GFCI protected?
As MTNEC stated the floor type is irrelevant as long as the space is finished.
I don't see why there would be an arbitrary designation of a mechanical room or shop as unfinished space. The space is either finished or it isn't w/o respect to its intended use. I don't even see why drywall is necessary to be considered finished. Paint is a finish and if the concrete walls are painted they are finished IMO. A lot of motels have concrete ceilings that are just painted. Those are certainly finished spaces.I agree that it's all about being a finished space. But what does it take to make an area a finished living space?
When you get a permit to finish a basement you are required to list the intended useage of each area. Game room, office, bedroom, mechanical room, shop. A game room, office or bedroom are required to meet critera for finished living spaces and a mechanical room or shop is not an will not be considered finished even with drywall and ceiling.
If an area is listed on the permit to be finished living space the electrical inspector should not tag the job for not having GFCI protection but the building inspector may tag it for not meeting all the critera for finished living space ( it's up to the GC or owner to deal with that).
I would have argued but that's just me. :roll:
I thought that the floor in this case is exactly what matters.
I thought that the floor in this case is exactly what matters. Concrete floors in direct contact with the earth have very high (relatively speaking) moisture content and lower resistance to ground. In my old house, you would actually get condensation on the surface in the summer, regardless of the fact that the AC was running.
The old saying? The OLD saying? :? Come on, I am not that old, and therefore neither is "Charlie's Rule." :happyno:Well that brings us back to the old saying...The Code says what it's says...
is there a difference between "finished space" and "finished living space"?
