hurk27
- Portage, Indiana NEC: 2008
When you have an SDS you will have a service disconnect ahead of it even if it is a MV switch, the disconnect at the building is now an article 225 issue as well as the wiring between the SDS and the building disconnect required in 225, the rules of 225 now apply and grounding and bonding is done like any out building. 230 is about utility service up to the point of the utility service disconnect after this it is a 225 issue if the service point is not at the building.
