greenspark1
- New England
A coworker recently brought this to my attention. Apparently you can tap a feeder and not provide OC protection until you get to the load, as long as you run outside a building and follow the other requirements of 240.21(B)(5). This seems counterintuitive since you could have a long run of tap conductor that could develop faults and would never trip the upstream device (on the feeder). Am I reading this correctly? What is the logic here?
The situation I have is 600A feeders being tapped with #12 wires outside and run up to 50' before a set of fuses are installed.
