mivey
Not being argumentative or struggling with the concept. I think you fail to recognize that instantaneous is not in the definition you provided. That is something you have assumed is implied even though we use this unit for both average and instantaneous values.From Wikipedia:
The watt (symbol: W) is a derived unit of power in the International System of Units (SI), named after the Scottish engineer James Watt (1736?1819). The unit is defined as joule per second[1] and can be used to express the rate of energy conversion or transfer with respect to time. It has dimensions of L2MT-3.
You seem to to struggle with that concept. Or maybe you are just being argumentative.
I noticed you highlighted "rate". Are you are interpreting that to mean instantaneous?
