jxofaltrds
Retired ESI
- Mike P. Columbus Ohio
- Creator
Ok....from a manufacturers perspective always double check what you read. for example if the SouthWire ampacity table has 6-6-6 at the 90 degree rating as 60 A when it is 55 A. Again, remember that manufacturers post things we (they) want you to read....always do your own research.
For example....this one is correct and it's not SouthWire -http://www.encorewire.com/wp-content/uploads/EncoreWire_ALCAT_SER.pdf
Love this part:
"The above data is approximate and subject to normal manufacturing tolerances."
So is it fair to say since the manf is 'vague' the NEC trumps this table?
In other words 'can' an inspector dismiss this chart?
