electricguy61
If you were to use a 250v receptacle for 120v, would you not be installing a neutral to a post that is designated for a hot?
Me thinks it's a violation.
I've got an L6-20R receptacle fed with 120V, for lighting.
The lighting fixture has a L5-20P plug.
The cord isn't long enough to begin with, so it is going to have to be replaced anyway.
Is it a violation of the NEC to put a cord and L6-20P plug on the lighting fixture?
Obviously, it will still function properly, but it is conceivable that someone might at some point try to plug it in to an actual 250V receptacle because it "looks right". And of course, bad things will happen then.
Most likely you want to look in the "white book", and I believe it is online.How can I look the listing on a receptacle?
Is there an online location with UL?
