Is there a good way to determing the number of, or size of ,stubups needed out of a panel that wouldnt be an over or underkill?
a job we're on has 2 loadcenters side by side and we were thinking of utilizing larger nipples into the gutter to get away from the random knockouts that are in them. both are 200 amp 42 circuit. Also if the nippples happen to be longer than 24 inches, do you derate for the amperage of the circuit or the actual load that its feeding?
If you had a 2" nipple that was 4' long jammed full of #12's on 20 amp breakers, what amperage would they derate down to?
