I know ive seen this question on here a few times over the years but cant seem to find it.
I need to power around about 8+ boat charging pedestals for a boat yard. The client is insistent on using 240v instead of 208 because of the refrigerators and air conditioners. Im sure most can withstand the 208 but he is sure some of the motors would burn up.
Service voltage is a standard 208/3. Im not finished with the loads yet but im assuming it will be around 50 kVA.
What is the best way to go about going from 208 -> 240. The load is to high to even consider single buck boost transformer and the Square D product selector doesent let me use a primary voltage of 208 with a secondary voltage of 240.
The last time I did something like this I had 480/3 available.
Thanks!
Thanks!
