Question about current in the neutral circuit. I think I understand if the load is perfectly balanced between the two 120 volt sides there is no current flowing in the neutral. If this is true then how does one calculate the current in the neutral if one side has for example a 100 ohm load and the other a 10 ohm load?
Thanks
Thanks
