iceworm
Curmudgeon still using printed IEEE Color Books
- North of the 65 parallel
- EE (Field - as little design as possible)
(posted in sureal time ccc)
On a 100 W 120 V bulb I read about 9.4 ohms with a Fluke 27. This applies about 0.004 V at this resistance level.
With 1.56 V applied the current is 0.0813 A and a calculated resistance of 19.2 ohms.
What voltage is applied for your 19 ohms cold measurement?
I'm not sure what part of this you missed:
[B said:iceworm][/B]
Tungsten lamps have a positive temperature coeficient. As the fillament gets hotter, the resistance goes up. Here is an example: These are nominal numbers
This has nothing to do with the OPs discussion. However, if you must know, I used a pecision 5000V source, current was 263.158A, pulse duration .001us. Energy delivered .001315J.
OP: This has nothing to do with your questions. I'm trying to get out as gracefully as I can for helping with the bunny trail. Tungsten temperature coeficient has nothing to do with the topic. I'm just jerking gar's chain.
ice
