Exactly, you can't do itIf I properly pig tailed (both hot and neutral) a 15 amp circuit, no problem. How do you legally stab a 20 amp circuit?
If you personally wired your own house, would you backstab 15 and 20 amp devices ?
Be Truthful
Not only will I not back stab a device in my house, I would never even use a wiring device that could be back stabbed in my house. The only devices that can be back stabbed are the bottom of the line junk.
I have used Home depot cheap junk in my home and likely will again.
They work fine to run CFL lamps, battery chargers etc. I don't usually plug heavy loads at the house.
Yes, there are lots sold, but it is just something I would never use.I have used Home depot cheap junk in my home and likely will again.
Ive made a lot of money repairing backstab devices
Yes, we know you like code minimum. But as for me I am what you call a loose screw, I seek for the best![]()
