kevn96
- JoDaviess County, Illinois
Code Question.. Recently saw a new install with service supply conductors connected to the utility on the south side gable of a building. They entered the building at that point via weather head and schedule 40 PVC. They travel approx 40' through non-accessible scissor trusses, that are insulated and sheeted with OSB on the bottom side, in the PVC and then exit the gable on the north side via LB and down to the the 400A CT cabinet. The panel is located directly behind the CT cabinet location. The question would be in regards to the conductors in the trusses hooked directly to the utility with out any OCPD. Thoughts?
