rlundsrud
- chicago, il, USA
What is the best method for doing a load calculation for a residential sub panel. The panel supplies parts of the house that main panel also supplies, so I am guessing you couldn't use square footage. Do you simply add up the known loads and make a determination from that? I only ask as I came across a sub panel that had an undersized neutral and when I added the loads it shouldn't have been derated. The house is still under warranty, so before I tell the homeowner to get it rectified, I want to be sure I didn't miss something. I doubt the EC that did this house would know how to derate it as he had bonded the neutral in the sub panel, so he clearly isn't very knowledgeable. I don't mean to overthink this, I just want to be certain before I cause a stir.
Thanks
Thanks
