Beenaround
- Louisville,KY
I have a question regarding the reset buttons on the front panel of Allen-Bradley motor starters. Do they have to remain on the door or can they be removed? I am asking this due motor starters being reset by general personnel without calling the maintenance. We have approximately 4000 motors, which vary in size from 1 H.P. to 1200 H.P. We have already had an arc flash due to dead short.
Thankfully no one was hurt. It seems to be an easy fix to remove the button so the door has to be opened to reset. I personally do not use the reset button. It is my preference to shut off the breaker, open the door check the starter over and either OHM or MEG the motor, and check for lose screws. Then reset the overloads, close the door and turn the breaker on. Is removing the reset button violating any code or U.L. listing?
Thank you all in advance for your input.
