K8MHZ
- Electrician
On a very popular ham radio site, QRZ, one op was complaining about AFCI breakers tripping when he transmitted on his ham radio.
I read the many clever ideas other hams were giving, like try to make filters with ferrite chokes. Not good ideas, just ideas.
I suggested a new subpanel with Square D AFCI breakers. Well, he took 1/2 my advice, but now there is no more false tripping.
If I was the person that had to replace 16 defective AFCI breakers with another brand, I would at least be talking to a lawyer about a small claims suit to make Eaton cough up the money it took to correct the situation.
I posted to him about the perils of using one brand of breaker in another brand of panel. If I can find a pic of a burnt breaker from a wrong brand type installation I will make sure he sees it.
So, not only is Eaton making a crap product, look what customers are doing to correct matters because they are FORCED to use AFCI breakers. Eaton knows they have a captive audience and as long they do they can make all the bad products they wish and still make money hand over fist.
So, the law makes man use AFCI to make him safe from fire. AFCI no worky like should so different brand has to be used in panel. This make man much less safe from fire than just using regular breakers.
Anyway, I thought I would post a solution to an AFCI problem. It seems the solution is to not use Eaton products.
New construction with about 16 Eaton AFCI's. Of course the contractor and electrical sub know absolutely nothing about the problem of AFCI's tripping due to RFI. I called Mr. Fello at Eaton, but basically he's given up. Nice guy, but as someone else mentioned on another board, Eaton probably just wants Ham's to 'go away'. He sent me replacements, even though my originals had the "ham" suffix. The replacements tripped equally. That is to say each time I try to tune up on 20 meters at least 10 trip. It's inconsistant as to which ones trip each time.
Well, I my electrician returned, replaced all of my Eaton Breakers with Square D, and VOILA, everything is hunky-dory. Square D's Homeline will fit (albeit snuggly) in Eaton panels, and they work fine. I'll eventually have a Square D subpanel installed and transfer all the Eaton breakers over to it. What a royal pain. My advice to any Ham building new contruction: INSIST on Square D for your electrical panel. While they are more expensive you will save yourself a lot of time and eventual expense if you want to stay in Ham radio.
