Toolteck
- Kokomo, IN.
Installing a 400 amp 3 phase panelboard with a main breaker supplied by an overhead busway. Is it a code violation to run two 3/0 cables to each lug on the panelboard main breaker instead of running a 600 kcmil cable to each lug. It would be much easier to hand bend the smaller wires into position in the busway switch and in the panelboard. 110-14 (a) says "Terminals for more than one conductor and terminals used to connect aluminum shall be so identified."
