- Massachusetts
You say rarely does lighting loads exceed 15 amps or something plugged into an outlet exceed 15 amps meaning it could happen, right?
And if it happens?
Worst case scenario the switch stops working.
Please consider this, there have been decades and decades of 15 amp switches being installed on 20 amp circuits. I don't see a trail of smoldering ruins.
You want something to ponder?
Check out exception 3 of 230.90(A) and consider the ramifications if the next installer does not do their due diligence before adding load.
The NEC expects that whoever is installing additional load to a service, a circuit, even a switch to do so following the rules of the NEC.
