Rigid connector for outdoor
JdoubleU
I need to come into a bottom of a stainless steal electrical disconnect with 3 1/2 inch rigid conduit. What is the name of the connector to use. I know its a silly question but I can remember.
Myers hub
or "conduit hub"
If you are coming in the bottom unless you are protecting from sprayed water etc, I see no need for a myers type hub.
Can you comment on conduit entry on enclosure sides vs bottom, vs top?
I know that tops of enclosures need waterproof entries. What about side entries?
Another and less expensive option to using a raintight myers [type] hub is sealing locknut(s):
