I agree. The answer I was thinking of was Lockrings.If you are coming in the bottom unless you are protecting from sprayed water etc, I see no need for a myers type hub.
Can you comment on conduit entry on enclosure sides vs bottom, vs top?
I know that tops of enclosures need waterproof entries. What about side entries?
On the side we are required to use these at minimum .Another and less expensive option to using a raintight myers [type] hub is sealing locknut(s):
