- Simi Valley, CA
One man's sloppy is another man's faster.:happyyes:
Why?..it's not required.Looks like a square D panel with a main breaker (200 amp?). Hard to see but...did they put Anti-ox on the aluminum wire?
I don't read Spanish, plus conductors are in the way so it is hard to quote a language one does't know all that well in the first place though I do have a few QO panels in the shop and they likely have same label installed in them if you really need to know, but if I quote it , it will be Spanish exactly like it is on the label - no English translationswhat does the verbiage say on that sticker?
I don't read Spanish, plus conductors are in the way so it is hard to quote a language one does't know all that well in the first place though I do have a few QO panels in the shop and they likely have same label installed in them if you really need to know, but if I quote it , it will be Spanish exactly like it is on the label - no English translations![]()
is this ~12ga copper passing through same hole ok with NEC? looks like screwdriver was needed to manipulate the solid copper into hole of bar on left.
When one looks at an uncropped photo that includes the left side of the left terminal bar, one sees a solid copper extending to the left that, to my eye, clearly corresponds to the solid copper you are calling out. I'd answer your question, "No, the solid copper is not passing through the same hole that the stranded is landed in."
. . . but that could just be reflection in camera.
you mean this offset? looking at right side, the bottom of right bar hole to the top of the left bar hole is minimal offset for a 12ga wire to bend into. but, perhaps you are right, pic illusion. but if the copper wire went right in then why is that stranded splayed apart from a tool?I've worked this terminal bar assembly a lot over my career and the notion of what it would take to create the offset in the solid copper conductor in the manner you describe strains credulity. The offset "could" be done, but, the ambiguity of the photo not withstanding, the "likelihood" is next to nil.
Old habits die hard. Its the way we've always done it
Yep...older wire and equipment we always had put it on. I don't even look to see if its required by the manufacture..... Just squirt it everywhere
like the noalox stuff? you just squirt it on? isnt that NEC violation?
I don't think you will find any currently used aluminum conductor alloys that do require use of anti-oxidation compounds. Go back 30 years or more and almost all conductors required it. The habit of using compound just has been carried on by many - and because it is a habit many believe it is required. NEC does not and AFAIK did not require compound the conductor listing instructions is what required it.Its required if the wire manufacturer or equipment manufacture list it as an installation requirement. There was no specific information given in the OP.
well, the Ideal noalox has instructions that say you buff the wire with the compound and then remove excess, thus using it just by squirting it all over would be a violation of the products' instructions. i am of course nit-picking it, but i was just curious. what do instructions for other makers of "noalox" say?Oya...what's the violation and artical?
