NYSolar
- Rensselaer, NY. Rensselaer County
If I was using SMA tri power 24000 that put out 277/480 volt, then wired to production meter. Then go to transformer , that goes to a disconnect witch line side taps a 120/208v service. My question is that if my numbers all worked out could I get a 120/208v boost transformer to 277/480v and use the PV ocpd to comply with OCP for primary side of transformer disco?
